Jotul 550 air draw
Ctwoodtick
2,202
Southeast CT
With the blowers off on this insert, I was doing smoke test on door for first time. When going around lower part of stove, inoticed there is some draw from underneath the stove where the blowers sit. No noticeable cracks in floor of firebox. I just read in manual that the air inlets for primary and secondary air are located toward the rear of the firebox. I'm figuring what I am seeing is the slight draw from those inlets, but for some reason figure that That would not show up on smoke test. Stove appears to be functioning as normal with dry wood. Any thought would be appreciated.
Sounds ok. Draft will create a negative pressure zone under the insert.
The primary air intake is under the decorative cast iron trim above the door with the slider in it. The secondary intake though takes its air through the bottom channel where the blowers are, so that is probably the draw you were experiencing.
Most likely you were seeing either the air inlet feeding the doghouse or the secondaries (or both). Not sure what you mean that would not "show up" though.
