- Dec 30, 2012
- 754
Ok so the insert has been burning steady for two weeks.
it heats the room its in if the blower runs.
so it performs as it should in my opinion.
I tried the fan on floor trick last night and low and behold the entire house is a constant 64 degrees including the up stairs bedrooms.
So I would think we maybe where @ 28 degrees this morning outside.
I am burning 2 year old maple and 1 year ash. If I put on a load directly from outside pile with just top cover I can see a noticeable stall in the stove for heat output. about 1 hour to get back to my peak performance.
For giggles yesterday I grabbed some 2 year old Oak and loaded stove with just 2 pieces on a 4 inch bed of hot coals. It took nearly 3 hours for the stove to get back to peak performance.
This insert is really intended for me to utilize my fireplace and to satisfy my need to constantly play with fire. So I am happy with the install and performance.
The addition of the box fan allows more heat to other rooms and the oil does not kick on in the early AM as it did in the past. thermostat is set @ 60 degrees.
So my seat of the pants experiment tells me that the temperature of the wood and the moisture content of the wood directly effects the BTU output of the stove.
And the hearth recommendation of a box fan on the floor blowing toward the stove does indeed move the heat!
