Hi, first time poster. I have a Jotul 3 gas stove. The pilot works fine but it won't light fire -- unless
! I take glass off, then it will light, at which point I put the glass back on. Clearly, this is not a great routine. Any thoughts?
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Hi, first time poster. I have a Jotul 3 gas stove. The pilot works fine but it won't light fire -- unless! I take glass off, then it will light, at which point I put the glass back on. Clearly, this is not a great routine. Any thoughts?
I removed the connections at the switch itself, and touched the white wire to the black wire, and the stove did not light.Did you take the copper wire and touch the screws on the switch? Just want to make sure it's the wiring and not the switch itself.
I'm not sure what a BVent stove is. My double tube vent comes up about a foot, makes a 90 degree turn and exits through the wall. I also am unfamiliar with a "spill switch." There's a simple toggle switch that turns the stove on when toggled up or down. The middle is "off." It's entirely manual; I don't use a thermostat. I can see the entire set of 3 wires that leave the switch and connect to three points in the unit below. It should be simple to just replace them. Thanks.Is this a BVent stove? You need to understand where the wires go. Ie is there as spill switch?
when I put a simple wire to the lower screw (THTH) and the other end to the upper screw (TH), the stove instantly ignites. Please tell me what I'm missing! Thanks.
I could not for the life of me figure out how that was supposed to work either unless their terminal strip was unlike any other than I had ever seen.....
