Hi all - I'm back from a long recess from woodburning. I reckon it's been nearly 4 years since I was last here. A lot's changed in my life but that's all for another time - I'm happy to bore you with all those gory details elsewhere ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Anyways - the main reason I'm here is because I know this group can help me out with my newest acquisition - it looks like a 1985 Jotul #3. I picked it up off Craigslist today and while it's in surprisingly good condition, I hadn't exactly noticed the true age on the plate when I scampered over to get it.
The basic setup: New house is a very well insulated WW1-era cape-style, and we only need to heat about 1500 sq ft at most. We only go thru a tank and a half of oil each winter. I've had 6 cords seasoning in the shed for years now, so my fuel supply is ready to go. Whatever stove we use is intended to be fairly central on the main floor, where I expect to build an oversized hearth and protector wall (we have no fireplace and can't jump into the existing single-flue chimney). I am expecting to go out the living room wall with triple-wall pipe, connect to a cleanout Tee, and then a braced vertical exterior run up from there.
Pix attached.
Questions:
Funky new software y'all have here...
Stove front:
Stove 3/4 side:
Stove data-plate:
![Jotul #3 - Should I Stay or Should I Go Now?? Jotul #3 - Should I Stay or Should I Go Now??](https://www.hearth.com/talk/data/attachments/110/110118-0fef77faa9da83216af93d05445ab850.jpg)
Pix attached.
Questions:
- Should we even bother with this stove? Or just turn around and try to re-sell it and not hopefully not lose too much $$?
- If we are OK to use this appliance, can someone please help me find a good exploded parts diagram? It really looks like there should be a top baffle plate inside it, and it sure doesn't have one.
Stove front:
![Jotul #3 - Should I Stay or Should I Go Now?? Jotul #3 - Should I Stay or Should I Go Now??](https://www.hearth.com/talk/data/attachments/110/110116-7361c73f8cc9f15b285de2cda75a53bf.jpg)
Stove 3/4 side:
![Jotul #3 - Should I Stay or Should I Go Now?? Jotul #3 - Should I Stay or Should I Go Now??](https://www.hearth.com/talk/data/attachments/110/110117-ae039a78d093fb2501f877572f2140a4.jpg)
Stove data-plate:
