My previous experience with wood stoves have been a Buck Mama Bear, a Sears wood circulator and a fireplace insert. I haven’t used a wood stove for years and wanted a something for emergency heating and an occasional fire. I am heating a 1150 sq ft ranch in central Va. I recently purchased a used Jotul 3 that is in very good condition that I am now ready to install.
I want to make sure the stove is installed properly with correct clearances. My challenge is limited space and I am not very familiar with what can be safely done to reduce clearance.
The Jotul installation manual says that if insulated pipe and a 05 950071 heat shield is used the clearance can be dropped from 34” to 13”. Who can I check with for the heat shield?
My understanding is the F3CB is basically the same stove and I have found heat shields for them. Can I safely use the heat shield for a F3CB on a model 3?
Without a heat shield I don’t think I can get the required minimum clearance. If anyone has suggestions or ideas I would greatly appreciate them.
