Jotul 3 Classic Direct Vent
Eweneek1
22
Eliquis
Have a Jotul 3 Classic Direct Vent stove. Lately been having trouble getting the stove to ignite. The pilot light is always on and strong. However, when I turn the switch on sometimes it will light and sometimes not. If it does not light and I leave the switch on it eventually lights. Would it be the the pilot generator causing the problem?
What switch are you using?
The one on the back of the stove?
The switch is on the front bottom right.
[Hearth.com] Jotul 3 Classic Direct Vent
That could be the problem.
Not sure of your capabilities, but to test it is not that hard.
Remove the spade connectors on the back of the switch,
& with a paper clip or a small piece of wire, connect them to each other.
If the unit comes right on & stays on, the switch is probably wearing out.
To remove it, there are clips on each side that need to be compressed & it'll snap out.
The replacement will snap into the opening. Re-install the spades & you're good to go.
I'm having the same problem with the same stove. If I determine it's the switch, can you suggest where I can find a replacement switch for the stove that can be snapped back in? Thanks!
(broken link removed to https://www.ebay.com/c/1864551828)
