Interesting stoves , seems they don't cat ? But some different process . Any real life experances
Cheers
Cheers
No real experience but like yourself, I looked at them after someone else mentioned it. With the exception of some of the dimensions, it is amazingly simular to the oslo 500. I didn't notice, but being a toploader, I would imagine it doesn't have a baffle and reburning tubes. Not sure. Does anyone know if it redirects the exhaust to destribute the heat around the stove before exhausting to the chimney? Curious.Interesting stoves , seems they don't cat ? But some different process . Any real life experances
Cheers
Jotul said:. . .clean combustion technology, Jøtul now offers the convenience of top-loading in a non-catalytic wood stove. Utilizing Jøtul's patent-pending rotating baffle. . .
Do you have any idea how the rotating baffle works? I looked at their page but it wasn't clear, unless I plain missed it.(broken link removed to http://www.jotul.com/en-us/wwwjotulus/Main-menu/Products/Wood/Wood-stoves/Jotul-F-50-TL/)-50-TL/
The lever on the side of the stove rotates the baffle. You can see it in this video.
I was just providing info about the baffle. Instead of a cat, the F 50 uses a baffle and burn tubes to achieve secondary combustion, like ~ 90% of modern stoves use. The only thing different about the F 50 is that the baffle rotates open for top loading. I'm sure more 'real-life' feedback will be forthcoming from some of the F 50 owners.Interesting stoves , seems they don't cat ? But some different process . Any real life experances
Cheers
I watched the video. It was informative and it looks light the baffle is steel from the sound of it when it is moved. If you forget to close it, the baffle goes back to the original position when you put the top door down. The only problem I see with steel baffles vs vermiculite is that overheating can cause them to warp. Since this stove is their newest, I want to see what others have to say about it. The other models already have been proven. I have only used baffle stoves and I have seen but have no experience with cats. My buddy down the street has a woodstock with a cat and it gets supper hot. Anyway, that answers the question about top loading and the baffle plate. I haven't seen the price yet so I am wondering if they are out or they are taking orders.I was just providing info about the baffle. Instead of a cat, the F 50 uses a baffle and burn tubes to achieve secondary combustion, like ~ 90% of modern stoves use. The only thing different about the F 50 is that the baffle rotates open for top loading. I'm sure more 'real-life' feedback will be forthcoming from some of the of F 50 owners.
My stove uses a vermiculite baffle. Around 50-60 dollars at woodmanspartsplus.com and over 100 at Jotul.The F 50 came out last season. A few members here have one. I think list price is $2200 or $2400.
I don't think any baffle material lasts forever. As long as it doesn't cost too much to replace, I wouldn't worry too much about whether it's metal or ceramic. Yes, the cat in a Woodstock can see some high temps. . .when there's a vigorous secondary burn in the firebox, the metal baffle/cat shield gets heat from above and below. There were some issues with the cast iron piece sagging; replacement stainless steel part is $45.
