Jensen Wood/Coal Insert - Model / UL Approved?
Libisaj9
1
Michigan
Hello Everyone,
I need help finding the model on this wood fireplace insert. The only thing I see on it is the word Jensen on the little gold plaque. I am pretty sure this unit is UL approved but a manual or something would be great. Thank you all in advance.
[Hearth.com] Jensen Wood/Coal Insert - Model / UL Approved?
Hello Everyone,
You will have to pull it out and look for a ul tag. If there is no tag it isn't listed even if it was at some point. You will also be able to see if it's hooked up properly with a full liner.
Also that has been run really really hot to turn the paint that white. Check for damage
Moving to the Classics forum. I think this insert is from the early 1980s. The UL label should be on the side or back of the insert.
