Jensen 24A Woodstove help
bvstp
1
Hartford, CT
My house came with a Jensen 24A woodstove in the basement next to the forced hot air system. It has a large duct connected to the return air duct of the furnace. On the back of the woodstove there are 2 fans. One blows over the internal box pushing air to the return duct of the furnace.
The other has a smaller moter and duct coming from one of the flues. I suspect to draw in fresh air.
I have a couple questions that I'd like answered to have a better understanding on how this will effectively help heat my house.
First, the duct to the return air of the furnace is unfortunately located to the return air vent in my formal living room directely below the thermostat. That room gets warm thus causing the the rest of the house to be cooler. Should I blow this return and hope that helps the air get to other areas?
Second, I had hoped the wood stove could generate enough radiant heat for the basement. Only the front of it gets hot and keeps only the untiliy room warm. Any suggestions?
Anything you can suggest other than these questions would be greatly appreciated.
