Hello,
First post here, hopefully you guys can help me figure this out.
My pellet stove had an issue with it's high limit snap disc so as a test I bypassed it which confirmed the disc was faulty.
However my piece of wire fell off and created a short which blew the 6 AMP fuse on the control board and I'm thinking something else blew along with it but I don't know what.
Here's what still works;
Fan works
Fan knob works, adjusting it makes the fan turn faster/slower
Reset button works (The one that should control the power sent to the auger)
Basically I can light a fire and it will work but that's the problem it works way too much.
Even with the switch on (reset button not pressed, so normally no power to the auger) The auger is feeding pellets like it's on a mission to burn it all.
Doesn't matter what setting the fan knob is at, it will drop pellets like crazy and the flames gets pretty big (clearly it's not safe to leave it running like that for too long)
I don't think the control board is shot but I could be wrong.
high limit sensor / snap disc works (it cuts power to the auger when temps gets too high)
Suspecting maybe the low limit sensor?
If you've got any ideas about what could be wrong, I'm all ears!
Thanks
Fan works
Thanks
