Hi everybody,here's my stove story.i have a 2500 sqft 1730's stone house 2 ft thick walls lived here for about 7 yrs no insulation single payne windows.bought my 460lbs of heating bliss so we woudn't have to walk around with a tuque and winter coat in the house.the stove is huge will not fit comfortably in most peoples living room 27" wide 35" high 37" deep.can fit 20"splits n/s no problem e/w also works but have harder time getting fire going strong enough to start turning down once burns fine.burn times are very good actual fire time4 to 5 hours that with a 32ft chimney someone with a regular sized one 15 to 20 should actually be able to pull of longer burns,a wee bit of draft at 32ft .throwing off heat 10 to 12hrs but my house will make a bowling hot tea tepid in about 4 mins so it can make good heat.took a while to figure out how to get max out of stove.you need to have rolling flames i mean burning then you start to turn down air 25% each time ,found if you close it all the way and then open up a 1/4"you hit the sweet spot.it also has an option on the stove to run two heating pipes up from sto to help dump heat to another room,have not used it so can't comment,but seems like a good thin to have if you need to feed heat somewhere else in the house.paid roughly $1700 canadian for it really some of the best money i ever spent. In a well insulated house you could heat it with this stove alone sure of it. the window is nice and large for a nice view of fire.well thats it thanks for listening![Roll Eyes :rolleyes: :rolleyes:](/talk/styles/default/xenforo/smileys/rolleyes.gif)
