Fellows, Thanks for the information from previous posts. It has me thinking more about an IWB then the OWB. Few more questions
Looking at the boilers I would most likely get mine from New Horizon in Sutton WV.
They carry two models that would fit in my installation area the BIOMASS and the ATTACK DP. The Econoburn would also fit and Tarm is an option but further research will be needed to find dealer.
My plan at this point would be to run the boiler much like a regular woodstove without storage and adding wood throughout the day. As I learn more about the boiler and get storage get that hooked up at a later time. Does anyone see any problems with the above models running without storage? I have 4000 sg feet with high ceilings, lots of windows and will be heated with hydronic baseboards.
I have a propane boiler running that system right now. The guy at New Horizon told me to just hook the new wood boiler into the propane boiler. The propane boiler is in a 10 X 10 ft room attached to the garage which is attached to the house. There is one chimney in this room that the propane boiler is hooked up to. The new wood boiler would have to utilize this chimney (or build another one which i don't want to do) I have no future plans to use propane because of the cost. Should I just get rid of the propane boiler and plumb in the wood boiler in its place.
