The tanks kick off the install.
Sent from my moto g(6) play using Tapatalk
![It begins. Froling +1000 gallons of storage It begins. Froling +1000 gallons of storage](/talk/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20191115%2F808c8284f52860438a41ca0412188a10.jpg&hash=5cbbf4e95bc85b7e3baecfea1fb56f45)
Nhtreehouse a member here did just what your doing two years ago with a 1000 gal tank. I’m sure you can find his posts and pics.In case anyone was wondering this is how you install a 10-foot tank vertically with 9 ft of ceiling space.![]()
I was taught about using Hemp when i did my build,i did comparisons with two other procedures when i built my storage tanks,I used just pipe dope on a 1/3,pipe dope and teflon on 1/3 and hemp on the other 1/3Tested my tanks to 80 PSI,i tested my complete system at 80PSI when i was done.All I can say is if you weld in any additional fittings - pressure check many times and then do it again. Also sealing threaded fittings through out the system - I used multiple wraps of monster blue Teflon tape and then yellow Rectorseal #5 - not good enough and had several fittings leak. Spend the money on some locktite products - my difficult fittings were finally sealed with Loctite 55 and then Locktite aerobic thread sealant #565.
I used Teflon myself. I've done some plumbing in the past. 3 wraps of Teflon and a little extra crank on every fitting, I didn't have any leaks. I did however have one copper fitting leak. It was new but had a bit of green inside where it must have gotten wet. I cleaned it ok'ish and it leaked I had to pull it apart and do a good job cleaning down to all new copper. Live and learnI was taught about using Hemp when i did my build,i did comparisons with two other procedures when i built my storage tanks,I used just pipe dope on a 1/3,pipe dope and teflon on 1/3 and hemp on the other 1/3Tested my tanks to 80 PSI,i tested my complete system at 80PSI when i was done.
Anyhow on my tank test the only fitting that didnt leak were the hemp ones,tape and dope some would stop with more torgue on the fittings,there were 3 with just tape that would not seal.
When i was finished my system,zero hemp joints leaked,and 2 soldered ones did leak fro recycled fittings.90 % of my pipe and fittings were recycled
Howdy @chew72, Sorry to revive an old thread, but I was wondering what size angle iron and base plates you used for those good looking legsThe legs have been installed.![]()
Thanks for the detailed info! The local propane dealer fixed me up with 3x 192 gallon tanks and a 250 gallon tank so your design will provide plenty of margin. There will be more heat loss due to surface area, but the price was really rightThe angle is 3". I'll have to check if it's 3/16 or 1/4. And if I recall they are each welded with 4, 4" welds. I had a welder friend weld it. So if your looking at them they are welded on both sides at the top for 4" then a 4-6" gap then another 4" weld. We also noched the angle over the tank weld so it lays flat.
The feet are 8"x8" - 1/4" plate I made them that big as the tanks sit on Styrofoam as a thermal break.
Also I think having 16 inches of vertical weld on each leg was double what the calculated amount of weld needed to be to support the weight.
