I have a DHT 35t splitter. Last season it started leaking oil out of the shaft seal on the ram. I knew it needed work, but in the meantime I just stored it with a metal pan under it to catch the leakage. Earlier this year I got the splitter out, cleaned everything off, changed the engine oil, and was generally giving it a once over. When actuating the cylinder, oil started spraying out of the shaft seal. Upon further examination, somehow the shaft seal manged to be "pulled out" of the cylinder, creating a hole for the oil to spray. New shaft seal needed. Aside from the leaking, everything is working normally at this time. Instead of rebuilding, I ordered a replacement cylinder and installed it last night.
In addition to replacing the cylinder, I added a couple of disconnect fittings the cylinder. They are circled in red in the photos below (except for the shaft seal, the 'blue blob', which is also circle in red). As shipped from the factory, I had to remove all hydraulic lines from the cylinder and valve in order to remove the cylinder. This means every line after the pump was essentially dry, and full of air after replacement. By adding these fittings, I should be able to remove the cylinder (in the future) without having to break all the connections to the valve. Photos attached.
After putting everything together, the cylinder is cycling extraordinarily slow. Initially it was doing the "jerky movement" thing it does, when the lines are full of air. Eventually movement became smooth, but incredibly slow. In addition, the auto-retract function of the lever/valve is not working. If I push into the auto-retract detent, it immediately comes right back out...it's not sticking at all.
DHT advertises a 12.8 second cycle time. I'm currently seeing 1:35 on ram extension, and 1:55 on ram retraction. Almost 2 minutes each way. I don't hear any abnormal noises on retraction, but I hear a squising/swooshing sound upon extension. It's similar to the sound your garden hose makes when you first start it up, and there's air running through the hose. That kind of jingling-coin, squeezing-sponge sound. I've ran the ram full extension/retraction probably 10 times now, and it doesn't seem to be speeding up. I have topped the fluid up, it's currently just below the "max" mark on the dipstick.
Is this just an issue of the oil being completely emulsified with air? If so, is there a way to speed the process up, or do I just need to let it set (possibly overnight) between ram cycles? Or is there possibly something else going on? Anything I can check/test (I do not currently have a PSI gauge on it)?
