The white exhaust is primarily water vapor as a result of the moisture in the wood and the combustion process. Water vapor plumes evaporate quickly, usually within a 20’ to 100’ of the exhaust (dependant upon the outdoor temperature and relative humidity). An exhaust plume of water vapor indicates high combustion efficiency and very clean combustion.
What appears to be white smoke is a stove burning with high combustion efficiency?
When ever I see smoke coming out I give it a little more air because I thought these stoves, when burning right you won't see anything coming out?
