I would like to add a thermocouple flue thermometer to my zero clearance fireplace, an Osburn Stratford II, probably with the Auber SYL-2813AC meter since it has a second input I can use to monitor the firebox temp. However, I can't add it to the chimney pipe since it won't be accessible once the fireplace is fully installed. I'd like to keep it accessible so it can be removed for chimney cleaning and replaced if it ever breaks.
Easily accessible from the front of the fireplace is the internal flue pipe. It has an 8" OD while the flue is only 6", so there must be either a 1" air gap or 1" of insulation between the outer wall and the inner flue pipe.
Any issues with drilling a small hole here to install the thermometer? It is only about a foot above the baffle instead of the usual foot or two up the flue pipe.
![Is this modification a bad idea? Is this modification a bad idea?](https://www.hearth.com/talk/data/attachments/320/320943-71e1f510cacd8de054232f68aad8a7a5.jpg)
