I am installing a mixing valve AM102R-US-1 into my system to reduce the temperature to the radiant heating loops.
The installation diagram from Honeywell is shown below.
The extension to my system is shown in the next diagram.
In my diagram it appears that there will be no flow through any of the heat sources if a single pump is used.
If a pump is added with each heat source (like no fossil) and the existing pump is removed then there appears to be no flow through the cold supply to the mixing valve.
So, how do I reduce the temperature to the radiant loop without using another pump?
Thanks,
Steve
Thanks,
Steve
