Auger wasn't working. Got that fixed.
Dumb Move #1--pulled out the ash tray while current was flowing to the igniter. Very tiny spark noted.
![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
Everything continued to work fine except the igniter wouldn't heat.
Current status is that everything works perfectly except the igniter. No heat ever. I light a fire in the pot by match and the stove runs normally all day.
Igniter: 37.5 ohms resistance Wires are OK.
Based on advice in a forum I replaced the 12V 5-pin relay on the circuit board. This did NOT fix the igniter.
I have continuity from the gold contacts on the board to the 2 wires feeding the igniter and indeed all the way to the igniter itself. "Houston, we have continuity."
BUT
I do NOT have 12V coming down those wires. I measure 100mV or so.
Fuse #2 on the board tests with good continuity. Other fuses are fine, too, and as I said everything else works just fine.
Is there any other way to check the board? I don't see anything burnt or damaged. There are 2 variable resistors that appear to be part of the circuit but I can't read the numbers on them even with magnifiers.
Ideas? Any board repair service y'all can recommend?
May the pellet gods be good to you for any assistance you can offer. For some reason I just don't feel like paying $170/hr
! to have somebody do what I've already done.
Thanks a ton.
BUT
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks a ton.
