I purchased this house a few months ago and the fireplace was never really used by the previous owners. They said they used it while tearing out all the old lathe and plaster and building the addition and a couple more times after completed. They said they didn't enjoy it cause too much smoke came into the house.
Well I want to use it so I started looking in the repair and function of the fireplace. The main problem that I found was that the damper was not even opening while they were using it. It was old, rusted, and warped to the point that it would not open properly. I have since replaced that with a Chimney Lock Top II. So cleaning up inside the fireplace I have re sealed all the fire bricks on the floor and cleaned and painted the metal liner inside the firebox.
That is where I found what I am unsure about. The metal liner that is above the damper is rusted out and gone on the back wall. There is some insulation there and then the brick. the side pieces all look to be in good shape and connected to the back wall. I am sure that the years of no chimney cap has caused my problem of the piece rusting out.
Is my chimney and fireplace still safe to use? There is no way of getting up into the area to try to replace the metal without tearing out the whole fireplace.
I have included a link to view some photos of the fireplace and a video that shows the damaged area. Its not the best video cause I had to stick my arm up there with my cell phone and get some video of what was going on.
https://drive.google.com/folderview?id=0B9v7VQn_ukJPU2xicm9iMWNkVUE&usp=sharing
