Is Hickory worth it?
Boiler74
Burning Hunk
Nov 30, 2012
225
West Lafayette, IN
Got a load of hickory. My tree guy took one out on one of our properties. I split it today. Holy crap that sucked, especially on the trunk rounds. So dang stringy. Is it worth it, or should I pass next time? Will it burn that much better?
Reactions: Backwoods Savage
Let me know and I will come take it off your hands. I will split it and use it in a couple years:) .
Reactions: gyrfalcon and ScotO
Hickory can be hell to split, but it burns hot. It does coal up pretty good. Also throws sparks when you open up the stove door. Another thing, bugs like it a lot. I'd give it 3 years to season if possible well off the ground. Two years minimum. I love to have hickory in my inventory.
Agree with all four of the above posts!
Save some hickory sans bark for smoking it is excellent for this..
Ray
Because I hand split, if I run into hard to split hickory or elm, the rounds are shorter and splits fatter. It all burns in the stove if seasoned long
enough. Not worth killing my back or hands.
In a word, yes.
Reactions: ScotO
I'll add my two cents. I have two full cords of dry hickory that I save for the coldest nights of the year (below zero around here). I'm literally afraid to load my stove more than half full of hickory (I mix it with hard maple). When I add the hickory, my stove top will hit 650 degrees F for a good hour with the fan on high. You really do want some of this around.
Reactions: ScotO
+1...and the smoke smells great! :cool:
What kind of Hickory? And some pics would be nice. ==c
Reactions: ScotO and raybonz
Is hickory worth it?? ABSO-FRIGGIN-LUTELY! That's up there with the Creme de la Creme of firewoods.....
Yes, it takes a long time to season (2-3 years) after split and stacked, but well worth the wait! I save lots of hickory for use when cooking on the firepit......I haven't cut any in several years, but this summer that's about to change. I have 10-12 shagbarks to cut for a guy. I'll be milling some of the trunks, the rest will go in the stacks. Even without the trunks their is probably close to 3 cord of firewood there!!
Worth every minute of effort IMO. Keep a plastic garbage can around when splitting and toss the shreds into it for kindling. Works awesome. Just the odor of Hickory makes a difference to me. Heat is just a good byproduct!
Shagbark Hickory is the best wood on my lot,equal to Honey Locust & even a little better than White or Bur Oak.Dries in 12-18 months around here.Can be stubborn & stringy when splitting,is very rough on saw chains (the bark contains silica & is even harder than the wood itself),saw blades,plane irons,router/shaper bits & other cutting edges.But worth all the effort you put into it.
Hey Boiler, if you haven't gotten the idea yet, pretty much everyone would love to have some of that hickory, including me.
Yeah, I'm getting that idea. I knew it was good firewood, but didn't know if it was worth the trouble that splitting presents. Especially for the big rounds from the trunk, considering their size and weight. I'm using a 3 point hitch hydro splitter, but even with that there was a lot of cussing.
Thanks all.
Pics or it didn't happen, right?
  • Is Hickory worth it?
