I have an older Majestic prefab wood burning firebox and chimney. I’d like convert it to a propane gas burner with fireglass, as I don’t care for the esthetics of gas logs. The box is only rated for decorative logs. It doesn’t have glass doors, but a retrofit is available.
I’m not expecting much heat out of it, but I would like some, and it’s difficult getting a straight answer from people attempting to upswell me into ventless, direct vent, b-vent and other alternatives, instead of just a vented ”decorative” burner.
My question is how would my perception of heat compare between a wood fire and a vented gas fire in the same fireplace and chimney?
The story I get from some people is the gas fire would be barely noticeable, but this defies my experience that a wood fire puts off heat comparable to maybe a 3000-6000 BTU space heater which is plenty for me. Are there any metrics on what percentage of the rated BTUs of a gas heater make it into the room in a vented system? I understand that the reflectivity of fireglass may improve matters, and a reflective or radiant fire back may help too. I understand the flue would be required to be fixed-open with a vented install, yet I’d expect a retrofit of glass doors would help with air leaks.
Thank you.
Thank you.
