I've got a woodstove in my basement. It's got blowers on it and I have 6 inch pipes leading from the blowers up to a register in my living room floor. However, I'm still not really happy with how much heat is actually getting to the living room. I plan on installing a cold air return on the far side of the living to try to help the heat come up and the cold air go back down into the cellar.
I've got plenty of wood from my property ready to go.
However, I'm the only one who can stock the stove and therefore I only run it on weekends.
I'm wondering if I would be better off buying a heat exchanger for the my fireplace. I think i'd end up getting about the same amount of heat as the wood stove in the cellar but that's kind of why I'm writing this. I may be wrong about that.
Also, one advantage to the heat exchanger is that my wife or son could easily keep the fireplace going. I imagine that it will burn a lot more wood than the stove because I wouldn't have as much control over burn speed, right?
My fireplace does not have a cold air inlet. If I get an exchnager, should I also have a cold air inlet created? How is that done and what is the cost (approx) of having that done. Is it a mason who would do it?
I have now shielded the stove from this surface with a heavy guage metal heat shield standing two inches off the stoveback.
