- Sep 20, 2012
- 14
Hi All,
I've been lurking on here all summer and finally sat down to say hi and ask a few questions of course
this place has been a world of help for me and there doesn't seem to be a ton of Zero clearance install pictures so I thought I would post a few.
Quick history:
We bought our house 4 years ago and it had an old Blaze King sitting in the Garage that the previous owner had torn out of the living room and built a crapy corner mantel with an Electric fire place. Well we had a Huge Storm this winter and lost power for three and a half days....needless to say it sucked!
So I vowed never to be in that situation again with no back up heat. Especially since my job has me surrounded in an unlimited supply of free fire wood.
I started researching what I could put back in for wood heat. Rip the mantel out and put a stove back in? well the main floor is very chopped up so a stove would be OK but wouldnt get the heat over to the family room and other rooms on the other side of the house. We also really like the mantel and the Wife said we have to have somewhere to hang the stockings So we discovered Zero Clearance fireplaces, realized they would work perfect and we could duct heat to the other side of the house. PERFECT!
Ended up having to take down the old brick chimney that went up through the middle of the house (major pain) as it wouldnt work with ZC fireplace and it wasn't in the best of shape.
Ended up going with the Enerzone Solution 2.5ZC. We didnt have a ton of room to work with so I poured over all the manufacturers install manuals and found only a few that would work. the Enerzone won as it's made in Canada, fits perfect, approved for lots of different 6" Class A pipe and it was available in stock at a store in the next town.
I started the install myself as all the qoutes I got from the shops were RIDICULOUS. It's been about a month of weekends and after work but I'm just about done. the ducting in the crawl space took the longest.
The Fire inspector has been over twice now and likes everything and has given me the go ahead to cover it all up.
Here are a few pictures
So now I have a few questions before I close it up.
1 - since running it to test everything I have realized the Class A gets fairly warm, along with the ducting coming off the back I'm going to trap alot of heat into this cavity when I close it up. My question is if I put a Room to Room fan in the back wall up high (it would blow out above the kitchen cabinets) and a vent down low (it would be very close to the ducting going into the crawl space). I could use this trapped heat to warm the kitchen. Am I crazy?
Even if I din't use a fan I would think two vents would work with just convection?
Any help or ideas before I close it in would be great.
Thanks,
Scott
Quick history:
Thanks,
Scott
