Hello all and Happy Holidays,
I have a 1997 model 1990 Intrepid II that has a problem with opening the damper after it's been locked in place by the damper rod. When I want to open the door to add more wood, the damper rod would simply slide over the tab on the damper D-plate (but not touch it) and NOT open the door. I found about a 1/16" of free play where the damper rod fits in to the hole in the back panel on the opposite end from the damper handle. I made a temporary fix by fabricating a "shim" out of a washer and tapping it in behind the damper rod in that hole which forced the damper rod forward towards the damper. This eliminated (at least for now) the free play and now the damper rod engages the tab on the D-plate and the damper opens when I move the damper handle backwards. I was wondering if anyone else has had this problem (the damper rod doesn't rub against the tab on the D-plate very much at all) and if so, how they fixed it. My fix is working well now but I'm not sure if it'll last for 2 weeks or 10 years so I'd like a permanent fix. Would a new damper rod that was presumably less flexible work?
Thanks in advance....
Bill
PS: I replaced the D-plate with a new one from VC and it didn't help
Bill
