mtnmizer said:
			Some of the older house builders in this area were of Scandinavian decent,(swedes, finns)
and built houses with massive fireplaces in the center of the house.
They had a fireplace both in the basement and on the
main floor. The ones I'm familiar with just took a fire in the basement
once a day in mild weather and maybe twice in below zero and kept the
whole house toasty when all that stone heated up. They had hollow chambers around
the fireboxes that work very well at circulating the heat. Some of the later ones
had blowers with outside air and burned very hot. One builder had a Russian stone
mason that did one for my dad, very artistic guy.
A daylight basement makes for easy access to the wood pile but some had a dumbwaiter too.. If
they had a fire on both floors at the same time you had to open the windows and doors.
These guys have mostly passed on but their ingenuity lives on.. I wish I had a fireplace like that
but when I priced it out it was over 25K and out of my budget.
The Masonry Heater/Russian Fireplace tradtion does indeed live on, and may be experiencing a renaissance.  Kuznetsov the Russian stove designer reports that there is alot of house construction going on in Russia these days, and that most of it is taking place on the fringes of cities.  That is, beyond the range of the usual centralized, community-wide hydronic facilities, and beyond the existing natural gas lines and also beyond reliable electric power.  So they build their houses around masonry heaters, like the old days.  Chernov (Kuznetsov's collegue in N. America)  says Kuznetsov and his team have built over 4000 of these things, and are still going strong.
Chernov has an interesting explanation of why the traditional designs are the way they are...
"It is well known that each change of direction in the gas flow weakens the draft. The more "turns" - the weaker is the draft. Therefore, there is always a limit of how long the channels can be in these designs, and how much heat can be stored. Here, it is always a question of achieving the perfect balance: maximum length of channels without having the stove smoking and compromising the cleanness of burn. No wonder that such balance is difficult to achieve as many factors affect the gas flow. This is why, such systems are usually designed with "draft reserve" that means that "it is better to loose some heat than have the stove smoking". Obviously, this "reserve" lowers the overall possible heat retention. "
"It has been said above, it is hard to achieve the perfect balance between the heat retention and sufficient draft in these design systems. This is the reason why stoves, belonging to these systems, usually have a standard unchanged sizing of the firebox and the channels that has been refined in numerous installations over the centuries. Finnish contraflow stoves, Swedish contraflow stoves, grundofens and kachelofens: they all belong to such systems.  Wee call these "forced gas movement systems".
http://www.stovemaster.com/html_en/designsystem.html
Http://stove.ru
By way of contrast, the new interior designs ("free gas movement") allow for much more flexibilty -- to the extent that one might consider building one of these things and have some hope of success.
Nowdays, the beauty of elegant masonry heaters might still cost $25000.  But the 'heat' part is pretty straight forward, and not that expensive.  Chernov said the materials cost of the Perth (Ontario) boiler was about $3500, and that included $1500 for the heat exchanger.
This is probalby more than you ever wanted to hear about masonry heaters and such, but if you want to see what they look like on the inside, try this link -- lots of pictures!
http://www.heatkit.com/html/lopezs.htm
