For what its worth, I came across this.
https://docs.google.com/viewer?a=v&...P5RM4n&sig=AHIEtbQdKab-sO5kcGtNx9tF-IGedkAdkQ
That article seems to be EXACTLY how my Wood Gun burns best.
Very interesting. Everything I am doing with my Tarm is actually contrary to what is recommended in this article with the exception of the coals in the middle of the slit. I always thought smaller slits were better, thought 15% MC or lower was ideal, and thought it was bad if there were any coals or ash in the gas tunnel. Does anyone disagree with anything in this article?
Hello avc8130:
About your boiler and its primary chamber. Does the Wood Gun Have a tapered to the nozzle design?
How do you load the firebox with the varied sizes of splits?
Are the large splits over center, off center?
There has been much discussion here about small splits and very dry wood resulting in puffing.
Which can be resolved with larger more moist splits.
Not in ours either.Not from the members of my "underground"![]()
Not in ours either.the WG is a real mans machine and can handle big splits. No need for those fancy little splits. But I meant out in the open discussions.
With my Tram, no problems huffing, and quite frankly load it and forget it. Drier the wood, the better/quicker the storage tank gets heated up. This looks like typical OWB sales pitch. I was waiting for the "bonus" section about adding tires and garbage. They call that free heat?
This is my 4th season with my EKO 25 and storage,the first 3 years I used small splits and was able to burn a very intense fire for approx. 12 hours before allowing the fire to go out and completely go out ,I was then able to heat my house for the next 36 hours from the storage ,after which time I would need to start a new fire and repeat the whole process. In order to burn this intense fire I would need to use small dry splits as mentioned and need to feed the fire approximately every 2 -3 hours,by using these small splits there was a lot of gas build up which in turn created a lot of puffing,but since the boiler was in a out building that wasn't a huge problem.
This year I took different approach,I took a half of fire brick an put it in the middle of my nozzle so that approx half of the nozzle was blocked,fan speed was also decreased to 50%, I then used small splits only when my coal bed was really low and then only just a few to help re- establish the coal bed with larger pieces on top some times much larger due to the fact I had a lot of wood that was hard to split by hand.some of the larger pieces on top were no always dried to optical conditions but by the time they were towards the coal bed they were plenty dry.
What I was able to accomplish
*I turned my EKO 25 into probably the equivalent of a EKO 10 which was fine because it was still more than sufficient to heat my house,domestic water,while still adding to storage.
* Because I was burning at a slower pace I could get away with feeding the fire every 6 - 10 hours giving me what I feel was more freedom and I only let the fire go completely out maybe 3 times the whole winter ,which I believe also gave me more freedom because I wasn't trying to establish a new coal bed every 48 hours.
*Larger pieces of wood done away with much of the puffing problem.
* My fires were still efficient and gasifying properly with no smoke coming from chimney and always had the storage tank to push against preventing it from going into idle mode.
* I still had the option of using smaller splits in times when the storage was at the lower end of the spectrum.As with driving a car you know from experience when to give it more or less gas(acceleration) to meet your current driving conditions,I had the choice of doing the same with the boiler to meet my current weather conditions vs my current heating needs.
This approach may not be right with every one but I felt it to be very beneficial for myself.
