I have in the past frequently said nice things about the Harbor Freight Firewood Cart which is what I use to bring firewood into our house for burning - carries a couple days worth, goes over rough terrain well, and can be pulled up stairs without to much effort (I have 9.5 steps from the woodshed to the stove area, so this is critical!)
However like most HF products, it's built to a price, and not always the best of quality... The spoked bicycle wheels were kind of shoddily assembled, and while the tires were OK, the cheap Chinese tubes tended to go flat over time, and were not very sturdy... My advice since last summer when one of the wheels collapsed on me, and the other got really wobbly, (while using the cart to haul rounds out of the woods) was to take them to a pedal bike shop and have them trued and tightened, and replace the tubes...
When the wheel collapsed on me I did some shopping on the net, and found that it was actually cheaper to purchase a whole new cart than it would be to buy just a wheel. In addition the HF cart had a 22mm axle, and the aftermarket wheels all had 3/4" or other inch size bearings... So I purchased a second cart, but because I was able to get the old wheels fixed (though they have LOTS of wobble) never put it together...
The other day I had a friend that wanted me to help him move some wood, and since my old cart was full, I figured it was a good time to put the new one together.... Same deal with crappy tubes and tires - my friend managed to blow one of the tires while trying to inflate it, and the other had a bad bulge on it... Because we needed to move at least a small amount of wood that evening I decided to run on the flat with a half load of wood at a time...
Much to my surprise, I couldn't get the new cart into the door, as it was to wide! :coolmad: The old cart went through our doors at home w/ room to spare, so I figured the other door was narrow - until today when I went to bring the cart inside in order to pull the wheels off and deal with the tires - it wouldn't go through OUR doors either
:-S The new cart was at least 2-3" wider than the old one![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
After I got out the tape measure to find the difference, I rapidly realized that HF had changed the wheels - and the new wheels were MUCH better. The old hubs were about 2-2.5" wide, and had very thin wire spokes. The new cart wheels had hubs that were about 3-3.5" wide, and MUCH heavier spokes. The problem was they had compensated for the wider hubs by extending the axles on each side, so the cart was actually 30.25" wide, instead of the 27.5" that is listed on the product description... Makes the cart BARELY to wide to go through a standard door.
However it should be an easy enough fix - cut an inch or so off each axle, shorten the axle spacers to match, and drill a couple new holes for the cotter pins that hold the wheels on... This will make the maximum wood length a bit shorter, but the old cart would hold (barely) 22" wood between the wheels, so taking an inch off each side would still give me room for my 18" target length wood, and the stronger wheels will be worth it...
I'm replacing the tubes and tires as well - for the tubes I'm using a couple of the "never go flat" foam rubber "tubes" - expensive, but should last the life of the cart and then some... The wheels are down at the cycle shop getting trued and tightened - they might not need it as much as the older wheels, but still...
Gooserider
Gooserider
