interesting difference in black locusts and my biggest oak score yet.
Flavo
109
chaplin ct
I posted a bit ago asking about a thorny tree and found out it was a black locust. My original guess was tulip because of the large rings and wood color. Then the black locust that I got last week looked so different I never would have thought of tulip. The one w/ the small rings did have a few more trees around it that I'm sure made the growth slower.
Then the oak. The rounds were way freakin heavy and the biggest of them couldn't be split at the site. The wedges were just popping out after a few good wacks. When I got them home I tried hitting them w/ my brand new (read sharp) x27 and the head just bounced right off.
Nice score, those big dead rounds often seem to snap instead split. Nice counter tops too.
How many times did you try the Fiskars on that oak? It will bounce but, on the 3-5 good whacks I can get the biggest rounds to split.
Nice score. Tighten that chain!
Flavo said:
brand new chain that day and didn't realize how much slack had picked up. It was still tight towards the end of the day too. I remember checking about 2/3 of the way through the day.
That's a pretty keen observation on your part.
They'll stretch when new. Actually, I just read in an '89 Chain Saw Service Manual that you're supposed to break 'em in. Soak in oil before and between uses. Run new chain at slow speed for 5 min, pump more oil if your saw has that adjustment. Re-tension. Run saw some more, re-tensioning until it's stabilized. I'll do that from now on.
I always loosen the chain after I'm done cutting. Seems that I read that somewhere. Don't know if it help keep tension off the bearings, but it's just something I do.
Are you sure the split on the left in the first picture is Black Locust? The one on the right looks like Black Locust, but the other one looks like something else. I can't see the bark very clearly, but it doesn't look right for Black locust.
Very nice score!
Ray
Top picture Black Locust on left, Honey Locust on right?
I've split loads of BL, and it can look like any of those that you have there. Depends on where in the tree it came from.
And some dense woods like oak will at times bounce the fiskars no matter how many times you hit it, if the grain is twisted or spiral. Make sure you have as sharp an edge on the fiskars as you can get, that will help. Only other option is a hydraulic splitter, or chainsawing it, or using something with a sharper edge than the fiskars will take. My Gransfors maul will take a very sharp edge, enough to get it into just about every wood, but the fiskars won't take that sharp an edge.
Did you work around the edges of that big Oak round or go for the split in half? You should be able to peel around the outside and then work your way to the middle.
I process lots of BL over here, down to what you might call kindling, for my little stove.
It's a real challenge for a chainsaw, because it's so hard and tough.
Splitting it with a shiny old 6 lb maul is almost boring, but good exercise. Stems around here grow up to ~20".
I do let fly at 'em, and if the maul doesn't open the wood, at least it leaves a crack that can be "walked" across the round.
Forks & knots are different, but succumb to a quick partial rip with a chainsaw.
Ill slab pieces off of really hard logs and work my way arund till I have one big square log.
Flavo, excellent blog by the way. Great pics! Keep doing your thing.
I knew I was getting a rental splitter for some of the more stubborn pieces. So I didn't even bother to try again on the big rounds.
It was my 1st time w/ a splitter and will not be my last.
I like the idea of splitting the somewhat easy stuff as I go along w/ the scrounges. Then saving all the PITA stuff for the splitter once a year.
Thanks Ray, I haven't posted in a while and should do some updating.
Very nice pile of wood!
