Live in the pod and eat the bugs, you will own nothing and you will be happyThis part of the EU assault on its people to control more of their lives by limiting energy availability to individuals and their households.
I must say that is some very well written information, kudos to your post 👍👍Wood smoke is nasty stuff, but none of these articles are accounting for the changing annualized source breakdown that we'll experience over the next 30 years either. Most of the at risk above-ground biomass in forests is anticipated to be nearly completely burned away in that time from desertification and extreme weather events, given current rates of increases in burned acres/year. While our cars and stoves will be cleaner, the air probably won't be no matter what we do at this point - annual exposure rates will probably keep climbing for the forseable future. Always happens eventually, no matter how big your "fishbowl" is... Most world models from the past 50-60 years predicted the largest % of new depopulation pressure occurs from pollution.
Yes, that is the issue. The EU standards and testing are looser and very weakly enforced. Most of the stoves I see coming out of there and the UK would not pass US or Canadian standards.It's a nice study, quite detailed. Took a decent stab at quantifying non-local vs. local sources, local source breakdown, and IPE vs. non-IPE exposures. Most higher exposures were during those Intense Pollution Events, limiting burning during the warmer rainy days would make a big impact on mitigating the lions share of it, looks like. I don't even burn at all when it's warm enough to be raining for instance. From the link article on the eco stove standards they have in place for 2022, it looks like they are weaker than the CA/US standards for PM2.5, they are allowing 375g/GJ, where our standards here are more in the range of 40-60g/GJ of total weight PM unless I'm missing something. The one linked article says that compares poorly to new standards for high GVWR trucks that do 0.5g/GJ. They also miss noting that PM output from higher MPG direct injected gasoline cars is much higher than previous generation, indirect multiport injection gasoline cars - and is so far unregulated and unfiltered worldwide. Diesels with operational DPFs produce significantly less PM vs. high pressure direct injected gasoline at this point in time in a comical role reversal.
That surprises me. I thought it will be disappearing water resources.Most world models from the past 50-60 years predicted the largest % of new depopulation pressure occurs from pollution.
The ones I'm familiar with, food and water both have a sort of built in "fungibility factor" due to forced migration effects, and in models, those both mainly become production restricted at a certain point, in part by pollution. They usually do several runs of constrained models with varying assumptions on resource use, etc but the public models all exclude warfare. DoD public releases, World3 and the world3-esque updates, MEDEAS are all I'm really familiar with, but excluding war in the model constraints explains part of the reason for this.That surprises me. I thought it will be disappearing water resources.
Yep,down the road from me is a "saved/rebuild" old farm and house. 2 lane highway on either side,plus a frontage road. Horse pasture right up to the roads,about a 300yd distance between the roads. They seem to go through a lot of horses, always seems to be new ones there, old ones gone.A couple more elephants in the room for cancer rates are the proximity of the residences to airports and highways and freeways.
