intellifire plus ignition question
Bdkreutz
3
Pleasant prairie wi
Hello I'm happy to have found this forum!
One year ago we moved into our new home that has a Heat Glo 8000C IPI system.
I'm one week out of the eletrical warranty period and have needed to reset the IPI system 3 times in this week. So glad there's good YouTube videos on that process.
My question is what might I try to do I order to fix this reset issue?
It's simple to remove the front screen and see the red to green flashing light then turn it off for 5 mins and reset it. But it's just annoying.
Thanks for any suggestions
I would try cleaning the rectification rod with some steel wool or emery paper. It is located in the pilot assembly & is shown at the top center of this diagram.
Thanks for the reply: I can not locate the words Rectification Rod in the diagram any chance you could tell me what its by or what's around it.
Also what side of this diagram is the front of my system I just need to get some orientation. Once again thank you so very much
The "FLAME SENSE" rod is the one you want.
It will be the taller of the two in the pilot assembly.
If you have any doubts as to which is which, clean BOTH rods.
