muss said:My house is not all that airtight & i believe it really isn't all that insulated in the walls cause the heat from my oil furnace doesn't make it or stay upstairs & it's cold up there <3 rooms> and an oven in the summer .Attic has plenty though . Anyhow, i'm wondering when i get my pellet stove in a few weeks, if i should also have the installer punch a hole to outside for intake vent . One dealer said i would only need it if it was a mobile home & it was airtight . i dunno bout that . Also is there such a thing as going too big on btu's ? 1st floor layout is almost u-shaped & stove is going in 12 by 12 by 7 high and would have to heat all around the u . Very concerned as this will be a lot of $$$ for me . I'm looking at a Quadra-fire Castile . Please help . Also all 4 dealers i talked with , contract their installation work . All around the $ 300 mark & bout the same for their vent kit . Told them i wanted it to go up 3 ft once outside . They said no need but i think i read somewhere on here maybe that a few feet up outside was very good to do . HELPThanking you all in advance . R.B.
Deffy said:well i recommend a rise in the exhaust pipe. if the power goes out, natural draft pulls the smoke out of the stove. as for the outside air kit, and airtight houses etc... if you have an airtight house, you must put in the OAK for the stove to work properly.
if your house is not airtight, the stove may maintain a proper burn without it. it will suck air in from your house, use it for combustion and blow it out the vent outside. *but* since your house isnt air tight, the house is able to replace the lost air. where is this replaced air coming from? outside. cold untreated air replacing all the nice warm air your stove is sucking out. you may not notice in the first few hours or in the room with the stove, but if the rooms arent airtight at the other side of this U shape, you will notice the cold draft.
assuming you put in the OAK heres what should happen. your stove gets hot and puts out hot air. the air fills the top of the room its in and spills out from the door into the other rooms. the cold air near the floor will gravitate towards the stove room where it will heat up and flow out through the top of the door again. if you want to aid this process, but a box fan on the floor aimed *towards* the stove room.
if my house is real cold and i light the stove, you can see it happen with a tissue. hold it at the top of the door and it blows outward. hold it towards the bottom of the door and it blown inward toward the stove. kinda nifty. after all the air is heated this effect is less dramatic and it wont be as breezy.
muss said:I guess you guys didn't see that i posted this back in February ;-) Muss
MooreHaven said:You can never have toooooo big a stove IMO.
Buy as big as your pocket is deep, you won't regret it in the end I think. We're living in an old "loose as a goose" farmhouse with no basement for the cold air to drop into. When I installed the Harvester, I took my dealer at his recommendation for the size I needed for a stand-alone heat source. As I was replacing my wood heat, in retrospect I wish I had gone bigger as cord wood vs. pellet heat just isn't the same comfort level as we were used to.
The dealer also said I wouldn't need an intake kit because my old farm house was so "loose". He was wrong! The lack of one resulted in a house that never got warm and had a constent draw of cold air drawn thru every crack and crevice across the floor to the stove. We even had drafts where there had never been one before that we noticed. And of course the higher we cranked the stove to get warm, the draftier it got.
When the light bulb finally clicked on for me, I remedied the situation with 2" PVC pipe, an elbow and a ball valve, sending it down thru the floor under the house right behind the stove. Worked great. I went thru the floor as opposed to the wall because it made more sense to draw up from the drafty crawl space as opposed to making a hole in a newly constructed exterior wall.
slls said:That would still be in your house, go for outside if you do it at all. Inside it will draw in cold air, it will pump air outside that you paid to heat.
