insulation
spinner
28
southern ma
Is the pourable insulation as good as the insulation wrap and can it be remove from the chimmney if you would want to go back to a fireplace.
It works fine but it will be a collossal mess to deal with if you ever go to remove it.
It depends. There's a couple different ways to pour in insulation. If you use something like Thermix, it sets up like a light weight concrete and would not be real easily to remove. It would have to be knocked out. If you pour in vermiculite or perlite, this is a loose fill that could easily be removed. You'd just have to collect it at the base of the blockoff plate.
