Hi Everyone,
Birrrrrrrr
!!, it's been a cold one.
I have a question on placing unfaced, fiberglass batt type insulation between an existing prefabed fireplace firebox and a propane fireplace insert firebox, wheter the insert box is totally metal or is ceramic firebrick,(like a Heat & Glow FB Grand), with the sheet metal blower shroud that surrounds the ceramic fire box.
My question for this is that most existing fireplace fire boxes are quite drafty and I believe that the insulation between the two might cut down on the draftyness of the existing fireplace firebox and also help raise the temperature between the two, to so the insert sheetmetal firebox shroud shroud would not bang when the blower is activated and circulates the air between the ceramic firebox and the sheet metal shroud that surrounds it, thus preventing metal exspansion/contraction to the shroud and preventing the bang noise that is associated with it.
Thanks,
John
Birrrrrrrr
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks,
John
