Insulating my liner
Blacktop
16
northeast
I'm in the process of installing my first woodstove insert and have two questions. The chiney is 16' from fireplace to blockplate. it is brick then lined with 13x13(OD) terracotta? I have a 6" flex liner and want to know if I'm making a big mistake not insulating it.Its been used as a fireplace for 1/2 year and had gas logs in it for a few years prior to that.
next question is the stove has two provisions for venting on each side. Is this really needed. I do understand about tightly sealed houses just want to hear some more opinions and experiences.
My chimney is much like yours. I did not install insulation around my liner because I did not know any better at the time and discovered this site just after my purchase and install.
From what I understand is you will want to install insulation around your liner, this will keep the flue warm which will help in your draft and reduced creosote build up because the temps will remain more constant from stove to exit (same with insulating your air ducts from a furnace). I plan on insulating in the spring or as soon as the temps come up.
