was getting ready to fabricate a block off plate for my Buck 91 installation.
here's what I did instead .. insulated entire fireplace firebox including damper with 2,000f rated mineral wool. insulation is pushed up pass damper about 2ft. entire insert is completely wrapped with insulation from all directions except bottom. zone directly above insert is about 4ft thick.
purchased a package of 24in x 48in x 2in thick unfaced mineral wool .. 80 sq ft for $40 picked up at local building materials supplier. most building materials stores will not carry high temp insulation. but keep digging odds are someone local will have it in stock.
home depot and lowes can order it .. it's listed on their website. but folks working there will probably never heard of it.
holds the heat inside your insert instead of going up the chimney. substantial difference in heat output if you've got an massive outside chimney like mine.
my fireplace makes a Buck 91 look small
![insulating entire fireplace/damper w/mineral wool instead of block off plate insulating entire fireplace/damper w/mineral wool instead of block off plate](/talk/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv186%2Fo0pss%2FDSC03982.jpg&hash=78f6b34de82eb87f7bd91102a3e8c894)
![insulating entire fireplace/damper w/mineral wool instead of block off plate insulating entire fireplace/damper w/mineral wool instead of block off plate](/talk/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv186%2Fo0pss%2FDSC03992.jpg&hash=399fbaab4a13954d88676b34c19f4530)
![insulating entire fireplace/damper w/mineral wool instead of block off plate insulating entire fireplace/damper w/mineral wool instead of block off plate](/talk/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv186%2Fo0pss%2FDSC03983.jpg&hash=f4466802c1a1ac6479cd9304d909d150)
![insulating entire fireplace/damper w/mineral wool instead of block off plate insulating entire fireplace/damper w/mineral wool instead of block off plate](/talk/proxy.php?image=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv186%2Fo0pss%2FDSC03989.jpg&hash=7e13b33b4eb1b02dd951680c1f3a3814)
