Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
In my Morso 3610 it helps keep the heat inside the firebox so you cna get a good secondary burn going. Mine was packed solid with ash by the end of the year and was choking my exhaust so I removed it and couldn't evne get the stove body up to a couple hundred degrees.
Check online for an exploded parts diagram for your stove and if you see a blanket there you probably need one.
