Hello,
I just had a new gas insert installed in my home and it sits in a corner chase on an outside corner in my house. When the new fireplace was installed, the installers said they could insulate my outside walls behind the chase, because they were not insulated... only the 45 degree wall the fireplace is sitting in. However, they used fiberglass bat insulation with the paper facing towards the inside of the house, and now I'm concerned about this being a fire hazard. I believe if a piece fell down on the pipe of top of fireplace, it could be bad news.
The chase has been sealed back up, so I may have to get access to it by removing the outside siding, since I really do not want to cut another hole in the sheet rock. I'll try to add a picture shortly.
Thoughts? Thanks!
Thoughts? Thanks!
