I have discussed this a bit in the past and sitting at the same crossroads in a decision.
We have a late 1960’s brick single story home (1800 sf) with a masonry fireplace. The backside of the masonry fireplace is our uninsulated garage. FWIW, I live in WI.
We have a Vermont Castings Montpelier insert in the fireplace. When temperatures are around 30 degrees or warmer, the insert heats the entire home. Any colder and we have to turn on our furnace.
My question is, how much of a difference will insulating and installing a block off plate make?
A friend of mine has a VC defiant and when you walk in his house, you FEEL the heat. For our setup, you need to be 2-3 feet in front of the insert. If you are 7-8 feet away, you don’t feel the heat at all.
I feel I have 3 options:
1. Install insulation / block plate
2. Option 1 with a larger insert
3. Install a wood stove
Comments?
Comments?
