elkimmeg said:
For simplicity Craig HearthHand book Page 44 and 45
The Ht 2100 does not have to be listed for UL 1777 that listing is the same as UL 103 HT which is a higher listing
In retail SS 304 with insulation will meet UL 1777 SS 316ti meets UL 103 HT without insulation.
Elk, I don't have the Hearth Handbooks (maybe I should) - but I know the people who wrote them, and they are also on the committee that writes the National Code - perhaps I can check with them.
I still think this specific information is wrong! All these numbers and codes might be easy for you to understand, but they completely confuse me.
316 or 316Ti are usually specified when burning coal or oil, but 304 is plenty good for wood. I would like to see a particular manufacturers listing or manual which states that their 316 is approved without insulation, but that their 304 is not.
As an example, here is a page where you can download a manual for a Chimalator manual:
(broken link removed)
Quotes from this manual for UL approved liner:
CHIM-A-LATOR® stainless steel liner systems are available in 5" to 12" round diameters. The liner is type 304 or type 316 stainless steel.
Coal burning appliances must be connected only with type 316 connectors and liners.
The CHIM-A-LATOR® liner system is intended for use in an unlined chimney with at least 4" of masonry all around. It may also be used in a properly built masonry chimney with cracked clay tile liners. Another use for the CHIM-A-LATOR® liner is to provide a properly-sized flue for a wood burning appliance installed into a masonry chimney which other wise meets existing codes.
CHOOSING THE CORRECT TYPE OF STAINLESS:
Type 304 (or 304L) stainless can be used for wood, oil and low efficiency gas appliances. Type 304 can also be used as a fireplace liner. The high efficiency gas furnaces require another type of venting system. Refer to the manufacturer's installation instructions before connecting a liner to a gas appliance.
Type 316 (or 316L) stainless should be used for a coal-burning appliance. Type 316 may also be used in any instance noted above where type 304 is specified.
-------------------------end quotes from manual-----------------
There is no instance in this manual where it mentions insulation for either the 304 or 316.
I think Chimneysweep has it about right. The average consumer, dealer or even code official is not able to make sense of all the various numbers and EVERY installation and stove manual (which are often VERY different).
So we have to distill this information and keep it as simple as possible.
That is, in my opinion - and in order of occurence in the field:
1. Installing liner into an existing lined chimney of good condition for wood burning
Insulation not required - any grade of stainless that is designed for this job is OK
2. Installing liner into a defective or unlined chimney
Insulation required with ANY stainless grade
3. Installing liner for use with oil or coal
316 alloys will last much longer and are best for this application.
Performance is a separate issue - just as we know an external masonry 8x8 is not ideal, an uninsulated liner in an exterior chimney in Vermont may also cause problems. However, UL listing is for safety....they do not test products for consumer satisfaction.
That is my current opinion and I am sticking with it....for now.
