Hi everyone, I would like to ask you guys this question who have been through this many times before. I did a site search, believe I know the answer, but want to be sure. I have found some conflicting information on other sites. My dealer will be installing an RSF Opel fireplace soon. It will have the required 7" ICC Excel Insulated chimney. My chase is only currently insulated against the living area of the house. Here are the questions:
1-Do I want to insulate the entire chase, all the way up and on all 4 sides?
2-Insulate under the cap as well?
3-If the answer is yes, is there a special type of insulation that should be used? Or just regular, unfaced fiberglass?
4-Assuming yes on the insulation, should I also install plastic vapor barrier over insulation, as well as some type of fireproof material like drywall?
Just want to be sure I do this correct. Dealer is doing removal of old and installing new fireplace, but I agreed to do this part to help out. I wasn't sure about vapor barriers and where they should be located against outside walls vs against the interior of the home wall...sure don't want any condensation or draft problems if I can help it. I also didn't know if it was possible for the chase to be "over insulated". There will be plenty of room to maintain clearances whatever I do. I always appreciate the help, Thank you...Mark
here is a photo of the chase:
http://i405.photobucket.com/albums/pp135/mtj54/home2007f-1.jpg
