Ok. I got a wood stove from my cousin, its actually a pretty big one...
(broken image removed)
I painted the top green with high temp paint just to see what it would look like.... It doesnt appeal to me, which is why just the top is done. The weather here is deteriorating, so come next summer ima sandblast and paint the stove. I have all the equipment to do such, but thats next summers project...
Anyways, I have a shop, its 50' long, x 55' deep. We been using a gas furnace to heat it, but $300 gas bill every month at 40F plus the $350 a month bill for the house is a bit much in my opinion.
My father passed away Sept2 07, and we had only discussed this option breifly. He built the shop from the ground up so he knew everything there was to know about the building... he was also on the 'extreme' end of a professional diy'er... to give an example, we bought a 1995 E350 cutaway van from my cousin, in 1999. Well the van was too high to fit thru the 10' overhead door, so, we took the air out of the tires and backed it in on the rims... then, against the advice of both Ford, and Unicell, we made a horizontal cut, all the way around the body, and cut out a piece 6inches high, and then lowered the top half down, bolted it back together, and viola!
go here for pics:
(broken link removed)
ok, so ya dad was amazing... then theres me. Im 26. Dad got very ill about 10yrs ago, and i became the PCT. so, Im a bit handy, like i can do alot i set my mind to, but at the same time, like, im very cautions... SO here, i have this stove I wanna put in the shop... Now, i know with the proper parts I can put it in myself, however thats what im missing, is a parts list. I have the external piece:
and the stove itself. Can i use just ordinary 6inch galvanized pipe? I am going about 8ft to a flat ceiling. from there, its 5/8 fireproof drywall, with 2x8 rafters on a flat roof, with torchdown. Now, the beams are 16 oc. but I was gonna go up behind one of the main steel beams for the roof, here:
the 2x4 marks the spot of the pipe, pretty closesly.
That pipe is an air line for the shop air.
Now. Im not loaded here, which is why i am opting for the diy instead of pro install. the other concern with the pro install is there is ALOT of stuff in that shop that I dont want just some 'guy' i have never met before in my life knowing about whats in there. (so i post pics online instead LOL!)
Anyways, I was thinking, I could make a little galvanized box in the ceiling and put the 'through the roof' kit inside this box for added fire protection. Also, how many dampers do I need?
ANd one more thing, I was thinking about setting this stove on 6 cinder bloacks, 2 stacks , 3 blocks high to get it up off the floor about 16inches. would make it easier to telnd to, and your less likely to walk into it if its about waist high... any thoughts?
go here for pics:
