I have a question about the possibility of installing a pellet insert into a home with two fireplaces that share one chimney. The house in question has a stone and mortar duplex chimney that merges into one common outlet just above the upper fireplace. It’s my understanding a dedicated stainless liner needs to be ran up to the top of the existing chimney for the pellet stove. The fireplaces are problematic in this house because if your use the upstairs fireplace it creates a draft smoking out the basement where the lower fireplace is located, even though the flue is closed. Both fireplaces seem to suck more heat out of the house than they provide. The owner would be willing to forgo using the downstairs fireplace anymore if the insert hinders the ability to do that being there would be a liner running into the common chimney. My question is, is this possible? If so how close to the top of the chimney does the liner need to be ran? Also installing a dedicated fresh air intake for the stove would be out of the question because a hole cannot be made in the chimney. The picture is similar to the setup in the home. Any input is appreciated, thank you!
