Hello!
I moved into my grandparents' house in northwest Nebraska (you can see both Wyoming and South Dakota from a hill) a couple years ago and finally got around to replacing the flooring in an addition, and decided to pull out the 1974-ish Earth stove in the process. The old Earth stove was vented with 8" pipe straight through the ceiling, attic and roof.
I'm replacing the stove with a Master Forge WS110: https://pdf.lowes.com/productdocuments/e8112e76-7d98-4912-be79-39dc907f9a47/60397709.pdf
I know there are better options, but the budget dictates economy.
When I pulled out the Earth stove, which had single-wall stovepipe with a 12" rear wall clearance, I discovered that there was no real heat shield (just Z-Brick over sheetrock, nailed to the studs) and the paper backing on the insulation was charred, and the studs were pretty dark. The floor under the stove was fine--they built a Z-Brick platform. When I pulled out the stove, the stovepipe crumbled.
So...
The new stove should be here on Friday. I'm looking at replacing the stove pipe and the chimney. I'm hoping to be able to find someone local who has done this before who can help me out, but I probably need to gather up all the components from a store an hour and a half away.
Here are my questions:
1. What do you recommend for stovepipe? It already has an 8-inch thimble (not sure that's the right word) through the ceiling and attic, which seems to be solid, still. Would it be better to try to downsize everything, or to put in a reducer at the stove, or at the ceiling? The stove needs a 6-inch pipe.
2. What do you suggest for the chimney? The chimney on top blew over today in our 70 mph winds, but all the joints were getting pretty ragged anyway. 50 years will do that to about anything. The chimney is located on the lowest roof of a multi-level roofline. I'll try to post some photos.
3. I'd like to use old corrugated tin behind the stove. Is that acceptable? It should still have a 12-inch clearance. Do I still need to build in the 1-inch gap if I use the tin and have enough clearance?
4. Anything else I need to know about and am not thinking of?
Thanks for any help you can offer! I've read a lot on here and am always amazed at the amount of expertise (and number of opinions) you all are willing to share.
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302273-e377d7e0c9e9ecf64477009d77cc69cb.jpg)
So...
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302267-8d7844a2f679360648710361fd6af115.jpg)
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302268-862c67c454873399111318b95fc282d6.jpg)
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302269-461dd2eee0120dbc513aaed937839e53.jpg)
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302270-88d9dfcaf7d4df3b06178dc89e40f4f0.jpg)
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302271-7d38147104c7ed1ad6c34a6ef7de8e8d.jpg)
![Installing new stove in old house... Installing new stove in old house...](https://www.hearth.com/talk/data/attachments/302/302272-8d5d36118741adb5511ffc45846c0a63.jpg)
