Will be having the Lopi Freedom insert installed, that you all have heard so much about :red: , sorry.... The installer mentioned last year when I started looking at stoves, that the existing back refractory panel is cracked (not horribly) and the side metal panels are slightly warped. Will that need to be fixed before I put the insert (mounted extended not flush) in? or does the insert block enough heat that it's ok? I can take pictures tomorrow if that would help.
Scott <-----like you didn't know who it was...![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
