- Sep 10, 2007
- 2
I recently purchased a nice used VC defiant encore 0028 to replace my old Gibralter stove. I have a couple of questions:
1, Should I retain the damper in my stove pipe and still use it the same way to restrict the draft,(I have 6" class A chimny)?
2, Should I run it in cat mode all the time,(once warmed up) or can I run it in non-cat mode and control the fire with the bimetal draft and stove pipe damper?
3, Is catalytic mode for slow sustained burn or can I make it rock and roll,(in catalytic mode) on those -30 minnesota nights that we are blessed with?
4. I'm going to go over the stove before I install it, what should I check?
Thanks
Thanks
