Hello,
I purchased a house that had an Olympic Fireplace Insert in the fireplace. I had the chimney inspected and was informed that the insert was vented directly to the flue and the flue was damaged. I was given a quote for $3500 to replace the flue and make the fireplace safe to use. I have no interest in replacing the flue and using the fireplace without an insert, so I would like to install a liner and use the existing insert.
I pulled the insert out to take a look. I expected to see a round outlet, but instead there is a rectangular outlet. What is the proper way to connect this to a stainless liner?
Also, I see the tag states "MINIMUM MASONRY CHIMNEY AREA:144 SQ. IN. HEARTH EXTENSION". What is this referring to? If round, that would be a 6.77" diameter. Does this mean a 6" liner would not be appropriate?
![Installing an Olympic Fireplace Insert Installing an Olympic Fireplace Insert](https://www.hearth.com/talk/data/attachments/231/231274-d25baf0793172327190e82c9eeb0db5f.jpg)
![Installing an Olympic Fireplace Insert Installing an Olympic Fireplace Insert](https://www.hearth.com/talk/data/attachments/231/231272-c8cd95d24275d66b5487384d46055d1c.jpg)
![Installing an Olympic Fireplace Insert Installing an Olympic Fireplace Insert](https://www.hearth.com/talk/data/attachments/231/231273-37de9e3cdc5df9e9de74c1a6d6b0c9af.jpg)
