Installing a Pellet Insert into space from a gas insert
jpwinn
1
Hello all,
I have a (decorative) gas insert w/ logs in my new house (2 yo). It's in the family room with cathedral ceilings and really does not put out any heat. Its' direct vented outside. I would like to install a pellet stove insert into this space. I'm fairly handy and can/will do myself (if it can be done). My question is...can i install a zero clearance pellet stove into the space where the gas insert is? I'll yank out the gas insert, cap the line etc. Anyone have any ideas/suggestions on how to do this? you probably need dimensions and gas insert manufactorer plus some direct vent info.....but any info would be appreciated!!
Thanks in advance!
Jeff
If the house is only two years old, are you sure this is an "INSERT" and not just a built in direct vent fireplace? An "insert" would be inserted into an older wood fireplace.
Either way you can install most Quadrafire pellet inserts into either application. Give me more info and I can give more details.
