Lots of research and reading…and approval from my old lady…has lead me to doing this install finally. I’ll try and keep this short.
Basement is currently unfinished. Poured concrete walls reinforced with rebar. Basement is entirely below grade.
Stove: Kuma Wood Classic LE
Chimney: Duravent Duraplus Triple Wall
Hearth: poured concrete 5 1/2in thick
Walls around stove will be metal studs, cement board, and covered in Evolve Morterless stone veneer.
My first issue is getting the hole core drilled through my wall. I’m going to have to dig down around my foundation, pour some concrete, and block off a well for future chase construction around the exterior chimney.
The duravent wall thimble for 6in pipe is showing me an I.D. of 8 1/8in. My plan is to core drill a 9in hole…center the thimble in the hole, then back fill around the pipe with concrete or hydraulic cement. Am I on the right track here? The core drill available to me only has bits in 1in increments. So I have to go with an 8in or 9in hole.
