So, the used PF100 is installed. Getting my baffles tomorrow so it's not set into the trunk yet but it's just 6" away from it'
I messed up and put the sealant in the pipe and I either didn't use enough or it's meant for the outside of the pipe. When I started the PF, it's know for smoking on auto start. Well, it came out of every crack. What was odd is that it also came out of the cleaning cap, do I caulk that too? If yes then you cut out the caulk each time?
Other than the smoke and that motor hum (I think it's a little off balance, it's beefy at 2000 cfm), it's 85 degrees in the basement. I'm letting it cool down so I can recaulk each seam on the outside and tomorrow after the baffles are in place, I'm hooking it up for good.
Can I get a YAHOOOO!!
Can someone fill me in on the caulk procedures?
