Hello all-
I just found this place by way of searching for information on our (new to us) Morso 1BO stove.
We got it used, it's in beautiful shape, and I want to get it set up and running properly.
Our home sits in the middle of our 40-acre ranch, I'm not worrying about emissions restrictions or EPA regs, but I do want to maximize the efficiency and clean-burning possibility of this stove anyway.
From what I can tell so far (from what I've read here and elsewhere), some thought and time put into the setup and tuning of this model of stove will pay off in respect to efficiency and function.
There are steel plate baffles inside the burn box.
Two side panels and two top plates.
The top plates have 'V' shaped cuts and semicircular cuts in them, the 'V' cuts appear to fit on to wedge-shaped protrusions at the top of the burn box, the semicircular cuts facing the door and the wall opposite the door.
The side baffle plates have square notches cut into them, which would appear to want to face down.
The flue diameter -- looks like it wants 5" pipe.
The heat exchanger cover (ornamental casting, enameled) flange has a 5.1" bore, the heat exchanger top casting has a slightly conical 5"o.d. flange.
There's a short section of 4-1/2" pipe set into the top of the heat exchanger casting, but my guess is that the right way to go will be with 5" pipe setting over the conical flange.
From there it looks like a simple 5"-6" adapter and go to the ceiling.
My setup would require an 8'-2" straight vertical pipe run to an 8" Dura-Vent (existing) ceiling flange (just bought this house, someone removed the previous stove out of there before we bought it)...
Should we run a section of 5" (if so, how many feet?) and then adapt to 6" close to the ceiling - then go with a conical 6"-8" adapter or is it better to go directly to 6" from the heat exchanger?
My sense says go 5" for a good length (two to three feet..?) first for good flue heat and gas velocity -- any comments here?
Hopefully someone here has the right advice for us.
I'd like to get this up and running well before winter comes.
Last winter we got a week or so of -10F during the belly of winter.
Cheers
Tinker
Cheers
Tinker
